Tyre Pressures
The front size you mention is very close to standard tyres so I would say:
MK 2 OEM tyres:
Front: 205/40/ZR18 86Y
Rear: 245/40/ZR18 93Y
Front 2.0 bar (29 psi)
Rear 2.1 bar (30.5 psi)
Carl P":2b76ianm said:
What are the recommended tyre pressures for a Ph 2 with 200/18s on the front and 245/18s on the back
carl and james: the quoted tyre pressure is correct for any size tyre that you put on that particular vehicle, may sound stupid but think about it! the pressure is quoted in psi, pounds per square inch, all you are doung by altering the size is altering the inches. hope this was educational.
I don't find their overly sensitive to pressures. I run 32:30. Have done for years, on and off track.
