Tyre pressures?
Other than the recommended pressures stamped on the tyre sidewall I haven't a clue :)
I'm sure someone technical will have more input at some point.
Rears are the same, front is down to your preference really.
Mk1 cars run much lower pressures at the front and I found that even when I had 18s on I ran lower than standard mk2 pressures.
The lower profile suggests an increase in pressure is needed so start at about 23psi and experiment.
There's also a wider footprint so whenever running different sizes to OEM you have to use Renault's figs as a starting guide only.
I was usually about 30 rear 23 front but the whole car has been stripped now and will weigh a lot less with a slightly different distribution possibly so I will be experimenting again......Check tyre wear as you go.
