After major work on the car and a couple of additions:
TTV Flywheel
Ph1 Clutch
New Slave-Cylinder
New Input-Shaft-Bearing
I was prepared for new noises coming from the gearbox because of the TTV flywheel.
But...is it really that loud?? [smilie=icon_eek.gif] [smilie=icon_eek.gif]
[youtube]DD7XgRtdHIo[/youtube]
It shifts fine through all gears and makes a hell lot of fun with the TTV (emptied a full tank of fuel this morning
But it sounds sooo unhealthy, those videos just don't represent how loud it really is.
You can hear this grinding sound clearly when cruising in the low revs from 1000-2000rpm (at around 42sec in the video) in all gears,
Ideas? Normal? Nothing to worry about? Just keep the revs over 2000rpm? [cmilie=iconcheers.gif]
Maybe i'm just a Sissy at the moment :rollseyes:
iolin:
Edited for some extra information:
There is a grinding noise coming from the gearbox when the car is on idle. As soon as i push down the clutchpedal, its gone.
Also, when reving on idle with my foot meters away from the clutchpedal, you can hear that there is an rattling, additional to the enginenoise.
Doing this with my foot pushing down the clutchpedal -> no rattling
The vee already did this before the flywheel was fitted (it just wasnt that clearly audible)....well that's why the slave-cylinder and the input-shaft-bearing was replaced. :s
Normal Flywheel Chatter???
TTV Flywheel
Ph1 Clutch
New Slave-Cylinder
