hualpa_jo":i3r0zz3p said:Nigel's mentioning of Pure Motorsport caught my attention...
If some day in the future I decide to go for solid mounts (and I will) then THIS is what it's going to be. Makes a pretty good impression on me. Unfortunately I have never seen rear top mounts. Is there something out there somewhere? Possibly even adjustable?
Nigel, thanks for your feedback. Didn't realise you had tried the to fit the strut brace. Real shame since it should tighten the front end nicely, albeit rather overkill for road use. However, I was willing to give it a go as it presented good value as a package.Cold fusion":t4mkqbwq said:Dulan,
The strut brace fits fine but the tray cannot be fitted after the brace is in place without damage. if you cut the tray to make it fit eventually it will split in all the wrong places..
Nigel.
I know the K-Tec one does need the tray to be cut since it sits flat relative to the strut towers, and intrudes more into the middle of the luggage tray, but the one from Pure Motorsport sits a bit higher and only a few centimetres ahead of the strut towers, so was hoping that it would not require any surgery on the luggage tray.Cold fusion":2yo8vmu7 said:A strut brace would stiffen things up at the front and would improve handling by a minute amount.
I have fitted a strut brace in the past and had to cut the tray to be able to still be able to use it, the benefit of the strut brace was not really detectable, but I never took the car on a track where the benefits would have been detected. I do not think they are necessary for the road.
A new front tray in 2008 cost me £141.60 and it took 4 months to arrive.
Nigel.
Thanks for that Nigel. So what you are saying is that for road use the addition of a strut brace to the OEM suspension set up did not make any difference to the initial understeer dialled in by the factory, which is what I was kind of expecting to hear?Cold fusion":1tify4w0 said:Hi,
The strut brace does not make handling worse on standard suspension it did not make any detectable improvement so was a waste of time fitting it.
Nigel.
Lankan":2uisub0g said:Thanks for that Nigel. So what you are saying is that for road use the addition of a strut brace to the OEM suspension set up did not make any difference to the initial understeer dialled in by the factory, which is what I was kind of expecting to hear?Cold fusion":2uisub0g said:Hi,
Nigel.
