Am a new member and looking for some help or info,
have purchased a v6 255 and have a flat spot when pressing the throttle sharply, not fully just a quick blip, if you are gentle there is no problem, this only happens from idle. no ecu lights on, no fault codes, new plugs, new coils, new battery.
engine seems to go momentarily weak for 1/4 (ish) of a second, (shown on gas analyser) like it needs a jot of fuel , then picks up ok. i have tried two other cars, one the same one not, has anyone come across this?
thought the throttle valve was opening too quickly so removed and found the throttle valve to be out of spec, 600 ohms across pins 3 & 5 ( should be 1200 +/- 250) so ordered another, new one has the same spec????? this is starting to get expensive.
car drives fine once rolling with no loss of power. does not stall. just annoying.
any help appreciated.
