selecta701
When I pull away and through the gears up to around 3krpm I hear a strange grinding noise? after 3krpm the noise goes so im a bit confussed... The strange thing is it only dose it sometimes, I dont think that it is the gearbox or driveshaft as if it was it would be doing it all the time. could it be the clutch or gearbox oil??? the clutch dosenot slip if that helps, I have a mk1 vee with frsh, thanx
