itz_baseline
just out driving and whilst braking the above lights have cum on. checked the manual and suggests that the brake fluid is probably low. checked it and sure enough its low, but just above minimum. manual also says i should only use renault approved fluids 2 top up. i went 2 a garage and got sum carlube DOT 4 fluid which is synthetic based. i am currently out driving around so cud sumone do me a favour and check if this brake fuid is suitable and post back so i can check back on my phone and top up. many thanks
