Squeeal piggy, squeeal!
Miguel 4747
Noticed a high pitch squeeking noise coming from out the passenger side. It must be a brake/wheel issue as it is only at low speeds and continues when i dip the clutch. Going to pop round to ATS to get them to peek at it, anyone got any ideas what it might be?
Most probably a stone that's become caught, take it for a high speed run then stamp on the brakes - should (in theory) resolve the problem
Just took the Vee to Kwik Fit as the garage i went to yesterday were NFG and had no time to look at her. Within ten minutes, Kwik fit had the rear passenger side wheel off and found that a shim had sheared in half and was scraping against the inside edge of the alloy. Problem solved, and best of all, they didn't charge me a penny. [smilie=yay.gif]
