The speedo takes its signal from the nsf abs sensor, probably not the ring but the sensor itself, they get water in them and fail.V6 Ade":3otrc8nz said:Where does the speedo get it's signal from, it's just when my ABS light come on tonight i noticed that around 40mph the speedo dipped. Have i got a bigger problem than i first thought?
i did say NSF!V6 Ade":2l03nxc1 said:Well, had a fault code reading today and come up with NSF ABS sensor, it seems the fault wouldn't store when the fault had been reset by turning the ignition off and back on again.
Anyhow, pick new one up in morning and only £125 incl the vat.
