SPEEDO ERRORS
Spike
I read the post on how fast is yours and saw this:
k1ano":355yvikt said:
I wondered about the speedo though as it should be pretty accurate, with the correct circumference tyres.
The speed sensor and speedo gauge are electronic and there is a fixed relationship between the final drive output, tyre circumference and speed. All that is needed is a correctly calibrated gauge which, on the Vee, clearly uses a stepper motor to drive the needle.
Maybe the French aren't good at maths :rofl:
i thought the speedo was driven from the near side abs sensor like on most other renaults, so the biggest problem we have is the fact that std size tyres are few and far between. can anyone confirm this?
