Im getting the following work done on the vee over the next week or so at Benfield Renault in Carlisle:
Replace front rocker cover oil vapour breather pipe (cracked)
Strip down, clean out and re-grease rear brake calipers (drivers side is sticking)
4 wheel alignment (tracking is well out)
Replace timing belt, idlers and tensioners (this has been marked as done in the service book but i'm having it done again for piece of mind)
Replace auxillary belt (running a bit noisy at the moment)
Total cost - £908 - pretty good I thought for a main dealer! I think the cambelt alone is around £1100 on the renault "quick quote" system.
WIll report back once the work has been done - I think a few folks on here have used Benfield in Carlisle before and had a positive experience.
