Scott (yet again...)
PhilGT
Just thought I'd post ref Scott G.
Left my phase 2 illiad with him 2 weeks ago with a long list of work, hoped to have it ready within 2 weeks..
Picked up day before yesterday.
Work done included:
new discs & pads all round,
remove exhaust (bosal) & fit new Spike exhaust,
repaint front bumper (usual speed bump damage - had paint before but mismatched),
address handling 'issues' ie didn't feel like the new one I had 10 years ago!,
rear number plate light not working (slightly minor I know)
remove wheels & tyres, strip, repaint & refit,
Supply & fit new set all round wheel nuts (old ones rusty)
treat rust issues on front suspension,
few other small jobs which I can't remember
Scott found out what the handling problem was - both front springs were broken - he fitted new suspension top mounts, springs & droplinks, also the brake discs had seen better days ie. the pedal was like standing on a wooden block and they were binding like crazy. They worked (if you really stood on them) but were not what I would like to call satisfactory. He spent a lot of time removing all the parts, drilling out abs brackets (onthe rear) etc which along with the new discs & pads has sorted the brakes completely.
The front valence (bumper) which is prone to speed bump damage was very damaged. The finished article is absolutely perfect. He took a great deal of time & trouble to do this properly, even removing a wing to ensure a good paint match for the painters.
Spike - your exhaust is the dogs. Sounds proper without being stupid (if you know what I mean) - Scott had to cut off all bolts & supply new ones, looks & sounds great. Problem was the fittings for the rear valence were all drilled out as most wouldn't come undone.
I must admit I was going to get a local garage to do the work, but all the positive reviews I had read about Scott persuaded me to make the 2-3 hour drive to Chippenham and see him after chatting on the phone.
For reference I meet lots of people every day through my business. Scott came across as a very genuine proper specialist who knows a lot about these cars and whilst he gave me a guide price for some of the work I felt comfortable and asked him to do what needed doing. This he did and he did a fantastic job, the car looks, sounds and handles so so much better than before. The invoice was what I was expecting for the amount of work and the long list of parts required (I wouldn't know where to look for half the stuff he needed) and so was the finished car.
What I would say to anyone with one of these who's looking for a specialist make the journey - as he's had so much experience with the Clio V6, Scott would be my only port of call.
Sorry it took me a day to type this but I haven't stopped driving it since...
Thanks Scott, appreciate it.
Oh and thanks to Spike for the sound....
PhilGT
Can someone please confirm that the following can replace the original V6 phase2 brakes and pads:
Front: Apec DSK 2779 with EBC redstuff DP 3036C
Rear: Apec DSK 2845 with EBC redstuff DP DP 31526C
Quick answer would be most appreciated as my car is stuck in a garage after failing the MOT. Kind regards to all, V6Veteran
Your part numbers all seem to be correct.
[ref=#000000]James[/ref], Thanks very much James: I'll go ahead and order the parts. If all turns out OK I'll feed back so above part numbers may help others in the future. Best Nick
Hi James and everyone else,
So far so good - rear Apec discs and pads fitted but front pins had seized and had to be drilled out! So my garage says I now need: ‘Front brake pad pins’ or may well be under ‘Pad fitting kit’. Does anyone have any bright ideas on this please eg: kit brand and part/kit number/spec etc. Thanks as always. Nick
Hi, a-pp.com sell ap spares.
Auto performance products rebuild parts, I purchased new pins and the little shims the pads sit on and new screws.
If my memory serves me correctly, I once ordered a set of these from Midlands (maybe Bromsgrove) based company. I tried a quick search, but no joy, but I definitely read it on here.
Anyone have any ideas?
Searched on “Bromsgrove” and found;
2 sets of 4 x CP6600-109 pad pins are in stock at
For B G Developments Ltd
Unit 9 West Court
Buntsford Park Road
Bromsgrove
B60 3DX
Tel: 01527 873716
Fax: 01527 575403
E-mail: [email protected]
Hope this helps.
Jit
Looks right. I just put all of these on my own car and the brakes are absolutely FANTASTIC. I did a drive over the penines and had nothing but 100% confidence.
These are the ones I bought for mine.
https://www.ebay.co.uk/itm/AP-Brake-Pad ... 2749.l2649
