reverse switch
  • Start date Start date
A
Anonymous
any1 replaced one of these im waiting for the part, whats the procedure to get it out etc. cheers carl
hi, real easy job.
once located (assume you know where it is already) - just unplug the connector - think you have to squeeze or pull some part of it to be able to pull it off. Then you need to use a long scoket - as it needs to go over the plug (the part looks like a big spark plug), i think it was 46mm but you can try it on the new part first.
then just unscrew, screw in the new one put the plug back on and job done1
