Hi,
Had the mk1 for 5 days now and noticed that the reverse lights are not working
Ive had the green connector off the gearbox switch and used some wire to bypass the switch and both work so should be the switch, however I read somewhere that it may be the alignment of the "lever" which acts on the switch inside the gearbox and doesn't operate it. Is there a easy way to tell if its the switch i.e using a multimeter to measure the resistance of the switch open then closed, i they are different resistances surely the switch is operating ok?
Don't really want to shell out £30 for a new connector which is never going to work lol
Also is this the correct part number for the switch as found it on here from ages ago lol?
82 00 008 194 REVERSE SWITCH L2
Thanks for any help,
James
James
