AlmostMechanic
Hi! I've asked quite a couple of questions, and finally managed to get the engine working! So therefore time for some results!
There was a vacuum leak between the carburetor and the engine, dirty spark plugs and a mistake in the firing sequence. After some tuning the car runs pretty smooth.
The following steps to make it road-ready are:
- Replace brakes discs, brake pads and brake hose.
- Repair the shift mechanism (reverse doesn't work and seems to be 1st gear, also all gears are hard to find)
- Repair the choke lever
- Replace back-left wheel bearing
