Removing Quicksilver Exhaust..........
ClioSpyder
I've just had a look at my Quicksilver exhaust as I want to remove..........
Now is it just me or can this be removed without taking the back bumper off ?
It looks "doable" to me, any thoughts ?
Yes it's doable mate, just a bit heavy when it releases from the 2 clamps so take the weight at the centre of the back box with a well placed jack ;)
Thanks for all the tips Gents.
Yes I know that statement is nearly as bad as "Pulling the rubbers off will be hardest bit" [smilie=icon_eek.gif]
Or, like on my car, the rubbers might fall apart in your hands!
Long ratchet arm extension and someone to lend a hand whilst you unscrew it I found was the easiest.
Liquid":3k3cnz4f said:
And become a contortionist for the bolts in the far corner...
yea the corner bolts are a challenge, having said that i took my bumper off, cleaned the exhaust, turned the grilles upside down and put it all back together all from my wheelchair! so its definately do-able
Ian
Ian
Quite unbelievable and inspiring pal the amount of work you do on your vee. :approve:
Thanks Matt, its all for the love of the Vee, i sure as hell wouldnt be a caring if it were just some old 'runner'
Removed the back Bumper today to remove the Exhaust..............now all sorted :approve:
My question is the small box that sits above the Exhaust that I'm guessing is called the "Collector Box", if this a Cat or just another Baffle section ?
Just wondering what it does as I was thinking of removing etc etc.
As always learning as I go along............
