rear track rod rose joint spacer
I MAY HAVE ONE but having looked in the knowledge base i cannot find which part you are on about, give me the item and page number and i will look again.
Took a while to find it but it's item 16 on the diagram.
image.php
Well actually it is a simple spacer that forms part of item 16 - I guess Renault are going to try and ream me for the full unit at a ludicrous price. If that's the case then someone is going to be doing some lathe based work and Renault can poke it..
Cheers spike. I've got some being made up this week.
As they are having to set up the cnc I've asked them to run a few off. So if people need to stick two fingers up at Renault, I can help.
would there be these images to be displayed?
I had the same problem ..
and it would be good to see a complete implementation of
