Rear lights playing up...
  • Start date Start date
A
Anonymous
It's bizarre, I can't seem to have my indicators and side lights working at teh same time. It's an either or dependning how I far I push the plug. If I opt for teh side light, the indicator won't work but the side lights flashes instead when I go to indicate... weird. It's just on the passenger side tho.
Some reckons it's the plastic bit that holds the bulbs (tech speak FTW) as they're apparently a poorly made part on most cars. Anyone had this experience and can say for sure?
I had a similar thing with mine..
Make sure that the connector at the back of the rear lights is fully located, mine was very very slightly loose..
If i had my lights on with the brake pedal pressed and indicated left everything went crazy lol.. sorted after that tho!
Mine used to be very odd. Take em apart and clean them up real good - it's all the corrosion and crap that gets into their awesome frenchness.
Dan
Doh... that was the plan but somehow I forgot to do it this weekend. Next weekend I guess now.
