Rear Fog Light....
Ashy B
Could someone tell me if two fog lights come on on the back of a MK1 and also on a Mk2 or is it just one? And also which side please,
Also Im having a right game changing my Mk1 rear lights to the MK2 lights.... on my right wiring plug I have different colours to what is mentioned on the how to guide, The left side colours are the same as the guide but im not sure if that is the correct way either now seeing as I can't get both sides to work with each other!
Has anybody else fitted MK2 lights but had different wiring colours to the how to guide in the knowledge base?
Any help would be ace!!
Tar!
Reading posted on the other forum.
"common thing when putting mk2 phase 2 rear lights on, only one has power to it. You can wire it up to work"
"ph1 only had a fog light on the right"
"I found the same when I fitted mine, I like things to be symetrical I just have the bulb in (even though it does nothing) I couldn't be fussed to wire it up. "
:approve:
thought it was only the right side, weird how they put 4 bulbs in each cluster though.... :s
