Rear discs and pads?
dwrights
Hello, Does anybody know where the best place to find some rear discs and pads at a good price. They don't have to be genuine Renault.
Cheers,
David.
Can't find anything on Ebay.Well give K-Tec a call tomorrow. Are the rear discs only made for the V6 or do they fit other Renaults?
Don't think they fit other Renaults ... but maybe Citroens, since the story goes that the rear brakes on a Vee are the front breaks from a Citroen.
Unfortunately when it comes to front brakes tho' it appears the discs are unique to the Vee and hence Renault get to bend you over and royally shag you ...
k tec rekon they have front disks which are cheaper than std renault ones for the front
It's the rear discs I need but I don't want to pay £250!! I shall look into it futher.Cheers.
Let as know how you get on.
The discs are made for the V6 only.
Try Scott.
Rear pads are the same shape as Cotroen but different friction material.
Try Scott.
Have been told that Renault and K-Tec have no rear discs untill the middle of January because they are on back order.
If anybody has a set lying around could you pm me please?
Scott at SG does front and rear discs for £125 (per axle pair) i believe
