Rear Disc's ABS Ring
Arj256
I need some new discs.
Am i right in thinking i can take the ABS ring off my old discs and put it on say some Clio 16v rear discs?
Or would the rear discs have to be ABS specifics to allow for fitment.
What rear discs are shared?
Thanks.
The land on the back of the disc to carry the ring is the same so you can fit either (discs are not specific), but a Bendix system wont read/work with a Bosch ring and vice versa. Bosch rings have 32 teeth and Bendix rings have 48 teeth iirc.
Clio 16V discs are the same as 19 16V ones, yes. BTW virtually all discs have the ABS land machined on the back, whether they are listed as ABS discs or not.
Brilliant, cheers for that.
Will use some new Clio ones a friend has, and swap the rings over.
Was rather surprised to see a large crack in my current disc
