Morning guys, just a quick question . The rear slider pins in the trw type calliper , are they supposed to be different ? As in the Shape and size! I greased them up last Saturday due to rear pads binding snd after taking the pins out and checking for damage/grease It was apparent they are completely different after a clean and some new lube the smaller pin slides freely the slightly larger one does not ! i believe this to be the issue or part off at least causing the pads to "stick on" rear disc is boiling compared to the others on the plus did a brake fluid change over the weekend with no problems after reading plenty of horror stories I was nearly completely put off the idea ....glad i did it peddle and initial bite feel much better only had my 225 for 3 months ...another reason why i ask is I found a pic on eBay someone selling the slider pins which look identical to mine and they are also different.. So now thinking do i re strip and see if the holes are different to accommodate their appropriate size pin!!
