Rear brake discs
Big Iain
Anyone using anything other APEC? I think Reno are something daft like 600 quid :rofl:
I've ordered Apec and they're already below minimum size at 22mm thick. I would check yours out if you have them fitted.
Had to buy Reno in the end, Apec are now aware of the issue so if you're buying some make sure they are the correct size.
The OEM for the brake discs are AP Racing. I think it might be cheaper if you can buy from AP Racing dealer instead once you find the equivalent code.
6020013025?
They dont seem to cross over with anything obvious, which sucks...
rustedandrotten":3dlj5xno said:
Did APEC give any indication of when they will have the problem sorted?
I didn't speak directly with them but I get the impression it's not a priority. However if enough people 'moan' about it :rollseyes:
If this becomes a problem i'll get TTV to make a batch, or Hi-Spec to produce some bells to take a standard rotor. Easy fix :)
Oldskoolbaby":2mcedk6k said:
Don't RAOC already do them?
No idea, I wear a baseball cap, i'm under 75 years old and I don't smell of used teabags, so don't qualify for membership ;)
James":zpm3snwc said:
They either wore away quick or were too thin to begin with. I guess the latter.
Hardly any wear ie no lip at all and already minimum thickness at 22mm, I will update with pics when I get them.
