Re: Up-rated Engine & Gearbox Mounts
HKSAR
Hi everyone
I would like to know where to find up-rated engine and gearbox mount for my Vee. Checked with Powerflex and GMT (Rubber-Metal-Technic Ltd.) but both they do not produce such mounts.
Trophy engine mounts are probably the only upgrade. You can turn the oem rubbers into a semi solid bush by moulding resin in between the gaps though.
Hi Brett,
Do you have any source for me to locate the Trophy engine mounts? Thanks
Alpineandy":1fr5pk70 said:
Could ask vibra-tech.
Can't see Vee mentioned on their web-site but maybe...
Hi Andy
I sent message to Vibra-Tech and waiting for their reply. Thanks for advice.
HKSAR":1qfwe9vb said:
Hi Brett,
I don't fella. I just remember seeing a track spec car using a ph1 engine with one so they obviously fit. They look to be milled from a billet part. There's always the easy option of rose jointing the bottom steady but you will get increased noise and vibration.
