*MrB*
For sale
Renault 5 GT Turbo RAIDER –
Fantastic history, I've not personally seen one with better history, all original books, service history, loads of old MOT's etc. Massive folder full of receipts and parts renewed/replaced.
Running 18psi and pulls nicely. Was set up by Tony at GT turbo spares.
Hpi clear.
Mot til September and tax til October.
Engine
Completely Rebuilt in 2007
Painted & Cleaned Block & Head
K-Tec Pistons & Liners
Oil Pump Overhaul
New Timing Chain & Tensionerr
K-Tec Uprated Headgasket
K-Tec Uprated Head Bolts
K-Tec Bottom End Gasket Set
K-Tec Sump Seal Set
Uprated Valve Springs
Uprated Valve Stem Oil Seals
Genuine Crank Spacer
New Water Pump
New Starter Motor
Stainless Steel Turbo Gaskets
Uprated Inlet/Exhaust Manifold Gaskets
Uprated Stud & Nuts
New Rocker Cover Nuts & Washers
Genuine Clutch Cable
New Throttle Cable
New Driveshafts
Genuine Thermostat
Black Distributor Cap & New Arm
New Engine Wiring Loom
Various Replacement Sensors Fitted
New Engine Mounts
Engine Modifications;
K-Tec KTR180 Hybrid turbo
K-Tec High Pressure Fuel Pump
K-Tec Metal Fuel Filter
K-Tec Stainless 2 & 1/2” Downpipe With Lambda Boss
Gas Flowed & Enlarged Turbo Elbow
New GT Turbo Spares Re-Engineered Carb
Re-Jetted for 17psi
Adjustable Cam Sprocket
ITG Maxogen Air Filter
Prospeed Stainless Exhaust with 3” Outward Rolled Tip
Cup Mod to Actuator Circuit
Mocal Oil Cooler With T/Stat & Braided Lines
GT Tuning Double Capacity Intercooler
Uprated HT Leads
Boost Controller
Engine Dressing
Full Samco Hose Set
Matching Vacuum Hoses
K-Tec Lobster Back Carb Elbow
Pro Alloy Header Tank
GT Tuning Top Water Hose Insert
Chrome Rocker Cover
Chrome Cylinder Head Plate
Chrome Engine Lifting Eye
Chrome Alternator Adjustment Arm
Chrome Cam Chain Cover
Chrome Lower Pulley
Chrome Alternator Fixing Bracket
Mikalor Heavy Duty Clamps
GT Tuning Oil Separator Pot
GT Tuning Swirl Pot
GT Tuning Ninja Oil Cap
GT Tuning Radiator Cover Plate
GT Tuning Turbo Heatshield
Polished Horn Pump
Brackets Painted/Powdercoated/Cleaned
Replacement Strut Top Covers
Body Work;
Original Raider – Restored in 2007/2008
New Genuine Renault Parts including Wings
New Headlights (Lucas)
New Indicators
New Yellow Fog Lights
New Washer Jets
Rear Wiper Removed & Grommeted
OE Grille
New OE Sideskirt Seals
New Door Check Straps
Suspension, Brakes & wheels;
GT Tuning Big Brake Fit – Front
GT Tuning Brake Kit – Rear
Painted Callipers
GT Tuning AVO Coilovers
Goodridge Braided Hoses
OZ Replica Wheels with195/45-15 Toyo Proxes (~1000 Miles)
Interior;
Custom Trimmed OE Seats
Matching Door Cards
Matching Cluster Binnacle
Replacement OE Replica Dials from RTOC
Polished Steering Wheel Boss
Centre Triple Gauge Pod
Stack Boost Gauge
AEM Wideband Kit
Stack Voltmeter
GT Tuning Short Shift Kit
Clifford Concept 650 Cat1 Alarm & Immobiliser.
No audio kit included but can supply a CD player that came in the car when I bought it if needed.
Couple of small jobs to do - top seal on fuel tank around sender, leaks when brimmed. Speedo head lazy but odometer works fine.
Drives superb, looks superb. No nasty surprises. Was thoroughly checked out by Tony at GT turbo Spares including compression test and checked top to bottom. Following my visit there I've fitted new rear wheel bearings, handbrake cables and sorted some electrical gremlins.
£4500.00
PM for more info / telephone number.
Hpi clear.
Engine
Oil Pump Overhaul
K-Tec Sump Seal Set
New Water Pump
New Starter Motor
Uprated Stud & Nuts
New Throttle Cable
New Driveshafts
Genuine Thermostat
New Engine Mounts
Re-Jetted for 17psi
Uprated HT Leads
Boost Controller
Engine Dressing
Full Samco Hose Set
Chrome Rocker Cover
Chrome Lower Pulley
GT Tuning Swirl Pot
Polished Horn Pump
Body Work;
New Indicators
New Washer Jets
OE Grille
Painted Callipers
Interior;
Matching Door Cards
Stack Boost Gauge
AEM Wideband Kit
Stack Voltmeter
£4500.00
