R19 Single->Twin Beam Conversion
Larry
Here goes, I have single beams on my current car although I want to put a set of 16v twin beam head lamps in there, I do also have the headlamp wiring loom from the 16v however to transfer that across firstly is it plug and play and secondly is there a method to doing this instead of transferring the whole wiring loom as its a fairly time consuming job, has anyone done this before without using the twin beam loom?
yep a ph2, the whole loom did seem like a pain, i noticed the horns were attached to it and side repeaters too although the screen washer and brake pad warning werent on the loom i got out of the 16v, would this have been some botchery by someone else?
also the colours on the 16v wiring are much different to that on the 8v car, do you know which colours go where or just figure it out as i go chris?
I would leave the original loom on the car and run the 16v loom along side it.much handier than trying to strip everything out.ya can always convert back to standard lamps without too much hassle if you need to
very true yeah, ive kinda put it on the long finger now, head came off the car today, there was coolant travelling from the head, looks like it may just have been a dodgy gasket
I'd suggest just making and plugging an adapter harness to the original to avoid any butchery.
That's what i'm doing to my ph1 E6J with 16v twinbeams. It's really simple to make especially when you have the bulb connectors.
Just 4 extendwires for the repeaters and 2 "light booster" relay kits with power straight from battery and control "signal" from original harness.
This will make the lights even brighter because of straight battery voltage (no loss on original thin wires) to give the twinbeams maximum power.
