PU (Polyurethane) Bushes Turbo Quadra Rear
sakurasanta86
Hello,
I have found a company that can make PU Bushes for me.
I have designed bushes for the renault 21 turbo quadra.
For now it is possible to order bushes for:
The rear wishbone (quadra)
The front wishbone (only cast iron)
I need a least 5 orders to make this a succes.
If this turns out oke then I can also make bushes for:
- The rear droplink
- The front sheet metal
- The rear subframe beam
- Other
The prices are:
- Rear quadra wishbone 23,75 per bush 47,50 per vehicle set. 2sets required.
- Front wishbone (cast iron) 23,75 per bush 47,50 per vehicle set. 2sets required
Al bushes come with stainless inserts. It is possible to choose between different hardnesses: Shore 95A, 80A and 70A and they will all have there own color.
Is there any interresed for this? I need at least 5 people for this to start up.
Maybe someone can make a list?
Thank you.
Wendy
Id be interested in the rear bushes yes... the fronts we can already get but rear drop links and wishbones I would like. I could probably get 2 or 3 others interested too.
Rear bushes for sure I would be interested in.
Didn't someone already start looking at this a few years ago and then it went silent? Same person?
