arno samimi
needed parts:
Ipod classic 6.5g 160gb, anthracite, engraved for the provided field of application (is used only for in / the MRS2):
navi antenna lengthened and soldered on mass:
also the radio antenna, and additionally split for tmc:
hidden install, and yes, reception is here:
mike the freisprechanlage also elongated to mass / provided with receptacle,
and fitted into the sun visor holder, and yes, you understand me best:
display from the CRS3, otherwise it works (the original cabasse display) not with the alpine interface:
specially prepared ipod console for the center-fold:
all the required line rates elongated to mass, so that it also comes behind almost like original:
double din frame adapted / painted high gloss similar to the oem look:
in it, and without bungle:
the original cabasse system completely removed, incl. the unneeded antenna cables,
and the right car boot cover exchanged with a "basic version", also a need for the following car audio installation, finish:
