markovic.mr
Hello fellas,
Thing I didn't tell you of my car yet is that I'm running it on LPG most of the time, not petrol fuel. It is cheaper and I don't warm up the planet
BUT, from time to time I like to run it on petrol, just to keep the injectors and overall fuel system healthy.
I have a problem with it, though. A car has very poor acceleration, hesitating and kinda choking. At the exhaust from time to time white smoke appears (when it's in its "choking" phase). NONE of this happens when I'm driving the car on LPG - it runs just fine, no white smoke or any choking or hesitating.
IAT checked - works fine
ECT checked - works fine
TPS adjusted long time ago, checked and it's fine
I have no cat(alyst) in my car.
Does anyone have any suggestions what can be causing my problem?
I think it's not due to stuck injectors - that's just the last thing I'll check.
Actually, I'm kinda convinced that the car is running very rich, cause fuel consumption is high (my fuel level meter works like a "second" needle on an analogue clock
- unfortunately it's goin' in the opposite direction)
I think I'll try to mess a bit with MAP sensor and I have a question: have anyone played with CO adjustment resistor? How can I check is it in the right position without measuring the CO level at the exhaust? I checked its position, and the pot is turned to the extreme left. So it's pretty suspicious to me - I guess it can be causing these problems?
Also, what's the little screw for - that's positioned at the top of the intake manifold? It affects the idle speed, but what it exactly does?
Thanx for the replies, I really appreciate any help.
