Woody
Hello all.
After this weekend and noticing everyones Pod Fans work, I've decided to try and get to the bottom of why mine don't!
I've not yet physically tested the Fans with a direct feed but I have shorted out the Engine Bay Temp Switch with no luck. Before I wire-in a switchable system, is there a relay somewhere in the original system for the Fans?
I'm thinking this may be at fault, as I'm doubtful that the ECU could take the full Amps to run the Fans. I'd like to think a signal from the Sensor would tell the ECU to send a minimul amp signal to a Relay to enable full current to flow. :s
[smilie=thanks.gif]
[smilie=thanks.gif]
