Pics of work done part2
EEE007
Replacement outside temp sender
Both front windows tint removed also
Both Door pull handles rubbed down ready for repaint
Steering wheel removed for refurb, OMP wheel in place for the moment
Full Service work to come
Cambelt
Oil/air/pollen filt
Oil
Brake fluid
Gearbox oil
Aux belt
Plugs
Brake pads and poss new discs
Clutch check/replace whilst doing above
Bank balance = £0
Iain
1.Rubbed them down with wet and dry paper started with a medium grit paper and moved to very fine so removing any scratch marks
2. Primed with plastic grey primer, halfords etc stock this
3. Left for 24hrs to cure
4. Sprayed with iceberg silver 2-3 fine coats ( same colour as car ) again halfords stock this
5. Leave to fully dry
6. 2 -3 coats of clear lacquer. ( extra tuff type used for alloys etc as it resists scratching better) again avail from halfords
Messed it up on one as touched it with finger b4 dry so had to start again, just take your time.
They look excellent now
Iain
Iain
Next 2 weeks will be:
Cambelt change/ water pump
Oil/filter change
All new plugs
Gearbox oil change
Fuel filter replace
Full coolant change
Done air/ pollen filter.
Sprayed door pulls silver and gear knob.
Full clean of all inner arches/ inside of alloys. Clean/Lubricate all moving parts and spray all fixings with water repellent.
Iain
How easy was it to get the mirror covers off? Is it just prised off like usual with a big flatblade screwdriver?
There's a strange mark on my nearside one, thought of getting it re-sprayed when I get my rear bumper done over the winter.
Thunderstarte - if you dont want to do your door pulls yourself the Spray Shack do them regularly. They have/had a groupbuy on CS recently
LINK
Spot on work mate! How did you clean the engine bay up? Mine has no covers at the moment so I'm thinking the same!
Also what discs are they you have bought?
Got some engine cleaner petroleum based stuff and brushed it on everywhere, and then carefully washed off, lubed cables and moving parts with spray grease.
Sprayed plastic. cable shrouds etc with silicon to add a bit if sheen
Iain
Disks are 2 piece type with outers and "inner bell" made of anodised aluminium
Weren't cheap at £450 delivered but are better than OEM for £350 in my opinion
And should be a Lilltle lighter.
Iain
Don't use a screwdriver externally as the cap and clips will break and make a total mess.
To get the mirrors back you have to take the mirror glass out first, this is clipped into a base plate and does come unclipped eventually - just be patient and the mirror will pop out of the base plate clips, you will need to get your fingers under the mirror and unpop the clips - a bit fiddly so take your time, then disconnect the 2 electrical connectors from the back of the mirror. Now remove the mirror glass. You will now see the 4 clips that hold the back on. Now just simply unclip the 4 retaining clips using a small flat screwdriver.
Cheers for that Mossy [smilie=thanks.gif]
Keep up the good work Iain :approve:, making me want to get cleaning mine now
