RSTuning
A little update on the G80!
After the terrible performance on the OG battle and some testing while we were at race wars we found that we're maxing the low pressure pump out with anything more than e30+-
The graph is comparing what the car made on e50 with 2.7 bar and e30 with 2.4 bar, for a couple of pulls on the dyno it seems to be able to manage to supply just enough fuel for the 1000+ hp but once you go through the gears on the road the low pressure drops very quickly causing a cylinder fill limit which in turn quickly reduces the actual fill target lowering boost down to only 2 bar from 2.7.
The 100-200 is what the car did only yesterday @ the lower power shown on the graph. Once we further upgrade the in tank pump we should be really moving!
For those who like to correct slope it also did a 4.42 with a 1.34% positive gradient going the other way.
(Feed generated with FetchRSS)
Continue reading...
Continue reading...
