Right then, please list what make/grade of fuel you use in your vees then? Personally I religiously only use Optimax and nothing else as my old R32 couldn't run properly on normal unleaded so have never given it a go in the vee
Was always Optimax at first. Then when Tesco came out with their 99RON super I swapped to using that for a while, but I found it hit my MPG by about 0.5MPG, probably due to the amount of bioethanol in the mix. Then when V Power came out I started using that again and have done so ever since, up until this week where I put some Tesco Super in because of the 4p per litre difference cf. V Power.
