PAS Pipes. Braided conversion Q
I've reached breaking point with the shite weepy PAS lines. I'm going to change them for quality braided lines. Thing is without pulling the system apart and then subsequently bleeding it again, I don't know what the threads are.
Anyone got the info for this at all? They should be pretty cheap to get made up, just need the union details.
I looked at this when the union kept letting go on mine. I can have a look later if you like. Mines all stripped out as I'm converting all my lines to braided due to the engine relocation.
Cheers Brett.
Replaced the rack a month ago with one from a breaker. Bad move. The bellow is now full of PAS fluid. So it's gonna be a case of rebuild the old rack and refit. May as well do the pipes when its off. I'd rater have everything ready to go though. If you can get the info, that'd be great.
If its not too much of an arse, could you get the lengths, if its stripped down. Then I can get a proper quote for a kit of hoses that people can then just order for fitting.
