Panel filter
  • Start date Start date
A
Anonymous
Is it worth replacing the standard air filter with an ITG/Pipercross/Green/K&N panel filter?
If so, can anyone recommend the cheapest place I can buy one from?
Cheers
which one? RS1 or RS2?
RS1, probably yes, because the original one is a bit too small.
RS2, put in a Green filter. Saves you a lot, doesn't make the droning noise, and works just fine in the standard airfilterbox.
Harry, mine is a MK1 Vee,
Im assuming the panel filters are different sizes for the Mk1 and MK2?
