Painted my wheels with Plasti Dip
phil b
So I have a week off and decided to do something with the Vee. I recently discovered Plasti Dip and fancied trying it out as everything I had read and seen about it looked good. Ordered 6 cans @ £70 and got cracking. The wheels on my car are looking a little tired so I thought I would paint the wheels and pods to see how it would look. You can also paint badges and trim really easily and looks pretty good. But the real trick is it can be removed at anytime very simply. You pick a hole in it and start peeling it off. It leaves no marks or glue as there isnt any. It just a plastic paint which covers and protects the paint. I think it originally was used to spray electrical connections to make them waterproof.
So I took the wheels off and gave them a good clean with some wheel cleaner and then with Fairy liquid. Then used pre paint cleaning wipes to get in all the smaller parts. Masked the wheel around the tyre and got spraying. 1st coat needs to give it 50% transparency. Leave it to dry for 15 mins and apply next coat. I found 4 coats gave it a thick enough finish. You also need to give it a good few coats as it is easier to remove if thick.
Then left them to dry for a few hours and fit back to the car. I found the finish to be pretty good considering it came out of a can and I sprayed them out in the open air. It has a matt textured finish to it which gives it a good effect. It feels a bit like paint that is touch dry is the only way I can drescribe it. You do have to be carefull with it when replacing the wheel bolts. A spot of grease on the side of the locking wheel bolt as its quite large and job done. You can also get a lacquer to give it a gloss finish.
If you get really close you can see a few drops of paint on one of them but it was my first one....
I would not say this is a permanent solution but a bit of fun. When I get obred of it off it comes. I am thinking of doing the pods as well and maybe the badges and will post some pictures once they are done. If anything, at least my wheels are protected from brake dust and a cheap way of customising your car. Think I have found the next way of decorating the car for Le Mans next year as you can spray a whole car. TBC
A few pics
Its been around for a bit and the fact it was used on electrical devices would probably indicate it doesnt have any corrosive side effects. From what i have read 6-12 months is probably a realistic time frame . I am keen to get some clear paint as this could be a good solution to protect front bumpers on road trips.
If you watch videos on youtube from dipyourcar.com you will see them covering the whole car.
Painted the pods today and it came out really well. Was good to get them off and clean behind them at the same time. How do such small fans make so much noise!!!
The more coats you put makes it easier to remove. It wont be a five minute job, more like 2 hours.... [smilie=icon_eek.gif]
Ali":uam9fizf said:
Do you think that looks better than silver? :S
Always liked the dark wheel / pod combo so thought this was the ideal way of testing it. I think the silver is probably the best colour for them but i like the stealth look of the black. It almost quietens downs the look of the car. In all honesty, if i decided to properly paint the wheels I think a gloss anthracite would probably be my choice. I do however like the fact I can protect my wheels in the winter in an easy an esthetic way. Time will tell how well it lasts but as I said this was more of an experimental project for a bit of fun. Will wash it next week and report back.
8)
I like it, it's given me thought for mine! My car is going into storage soon as I've just bought another car as a daily driver, could mean I get to mod the vee over winter.
Some of you will have seen the car yesterday at Silverstone. The car was washed with a pressure washer and i am happy to say that both wheels and pods were fine. I used a soft sponge on these items and turned the pressure down a bit on the wheels. As a temporary fix this seems to work. Now, time will tell how it lasts. Comments yesterday were positive but whether everyone laughed when i went to the track is another matter!!! :tumble:
