5 GT Turbo Oil Filter; which one for the 5GTT C1J engine?
LowiePete
Hello Folks,
This topic is a subject that I've long been researching an answer to, particularly as
some of the "popular" marques are seemingly no longer manufactured and are
fetching quite spectacular and stupid prices. The price of oil filters is going so far
north it's becoming a cheque-book sport. For what is nominally a simple service
item, that's just daft. The whole point of these parts is that they are changed
properly and frequently.
So, as the owner of a 2L petrol turbo Renault I was rather surprised to find that
the oil filters for the F4R engine have more or less identical dimensions as those
fitted to the smaller, historical C1J engine. I've broached this subject here before,
only to find objections because of presumed "oil pressure loss". To be honest, I
didn't buy those arguments then and, having done more research since, I certainly
don't buy them now.
If it means that I can replace the oil filter at frequencies of at least twice or more by
using one that has been developed for the modern era, that is for engines (and oil)
developed long after the C1J went out of production, then so be it. The idea that we
be tempted to "stretch" the life of filters that were previously specified because of
cost or rarity just becomes daft. So, with this overlap in mind, what should we look for?
Well, it's very simple, although finding the evidence for this simplicity has not been
at all easy. The first bit of research is in oil pressure measurements. The absolute
critical measurement is that the by-pass valve is not forced to open and let through
unfiltered oil until it's absolutely necessary. Next comes the flow statistics, that is
the filter not interfering with the oil pressure on the exit side. That can fairly easily be
answered by the physical dimensions. In other words, if the enclosure dimensions are
similar, then the flow will also be well within tolerances. Indeed, it could be argued
that flow, at a non-diminishing pressure, will be as good or better with modern filters.
So, it comes down to getting accurate statistics regarding oil pressures at critical
moments and making comparisons. Trying to track these down has not been an easy
job. They are, thankfully, available in tech publications from Renault. For the C1J it
came down to researching period publications. For the F4R they're found deep in the
Dialogys system. So, to the figures...
C1J Turbo
Revs @ 750 rpm (idle) 1.3 bar
Revs @ 4,000 rpm (turbo active) 3.2 bar
F4R Turbo
Revs @ idle 0.4 bar
Revs @ 4,000 rpm 2 ~ 4 bar
What the figures show is that the tolerances of the 8200 768 913 oil filter for the
later Renault engine will happily cope with the C1J engine. So that should make the
market for paying well over the odds collapse. I've discussed this at length with Karl,
my Renault mechanic of many years, and it's quite clear that he won't be screwing-up
his nose at me for substituting them. I'm not inclined to ignore his advices at the
best of times.
Like me, he's far happier that the filter gets a regular change, rather than sticking to
what is likely to be old technology at what is becoming stupid pricing. This especially
as the specs of the oil have not stood still in the intervening years either.
Regards,
Steve
Interesting read. Could the black market in Fram be about to collapse or will the OEM Kings keep it as a must have?
I have a stock of OEM fitments for the C1J, but I think I'll save them for the possible
purist owners who follow me. They'll add to the car's value if I sell it.
There's no manufacturer name on the Renault F4R filter, but if we assume that it's
Purolator, then it's a no-brainer. I've been doing a huge amount of reading about
oil filters and the internet is very, very short on proper facts and figures. However,
Fram seems to find the polar ends of love and hate, whereas the Wix seems to hold
the middle ground. Purolator seems to be regarded as fairly good quality, but also
seems to lag behind both as popular fitments.
I don't think that the advances in oil technology should be ignored in this debate.
Regards,
Steve
...or will the OEM Kings keep it as a must have?
My short answer is: What's the point?
I think the answer to that is dependent upon whether or not your car is to
be treated as a museum piece. At some point, maybe fairly soon, the
availability of "quality" filters will dry up, just as original size tyres have.
Yet, changing the oil filter regularly is one aspect of keeping the car
roadworthy that will not change. It's just a service item and paying
through the nose for it when modern offerings probably perform better
is just snobbery gone mad!
I wanted to edit my previous post by adding that advances in technology
will also include better filtration.
Regards,
Steve
I'm on your side with this one. Any oil filter with an M20 thread will fit, within reason. Yes there is always a difference in manufacturers items but isnt that always the case? Takes a bit of experimentation thats all. If you see a drop in oil pressure then cross it off the list and change it.
I think the OE GTT one had a one way valve in it to stop the filter draining oil back out down into the sump, keeping the filter full...but then the F4R one sits in the same place/same angle...not looked inside one to be honest. I have some at home so maybe I will have a gander.
I'll be using the F4R one on the 9 Turbo anyway.
Thanks Dave, I'll be continuing my research from here, but so far, so good.
I should perhaps clarify my comments regarding dimensions. The Purflux LS590
was introduced as a squashed-down version of the original original filter to allow
for limited clearance between block and fatter radiators used in hotter climes.
So, what's more interesting is that it's the cubic capacity of both filters that's
more or less equal.
The point of this missive is that using the F4R filter will not harm the C1J.
Fitting trials of the later filter comes next, but at least I have a standard rad...
Regards,
Steve
I have tried various filters with a mechanical oil pressure gauge on over the years. I have personally seen 10lbs pressure drop with the incorrect filter fitted which was almost the correct size (mecaparts), probably same as modern f4r filter by purflux. Cost me a turbo rebuild..
Plenty of stock sized correct filters out there cross reference the o.e number and bosch still available amongst a few other new old stock.
That's a >20% drop in pressure, so unless the filter was faulty, there was
something else going on. That kind of difference could not be solely
attributed to a functioning filter. There's nothing in the physics to provide
for such a significant drop, that's why I'm making the argument. The
F4R filter is perfectly happy in other turbo engines.
What about the LS218 that I've seen a few selling on eBay these days as a replacement OE filter for C1J?
As far as I can tell, that is / was the original original, only superceded by
the squashed down version when fatter radiators were fitted that stopped
them from being spun on.
Regards,
Steve
All gt turbos ran the same size/ thickness rad no such thing as thicker original. The 70mm thick rads have only come about in the last couple of years and then the rad is offset to the oil filter anyway.
Facts are small oilfilter - high oilpressure.
You cannot compare the f4r to a c1j regarding oil pressure. The f4r is leagues ahead in design you could probably stick any filter on and have no issues.
The issue with the c1j is the oil pressure is poor from stock and even with the correct filter you can struggle to make the textbook pressure when hot. All i done was change from fram ph4546 to the mecaparts filter and when hot noticed a drop. Have also seen a drop in pressure with another cheap brand filter many years ago on my white gtt cannot recall make now.
Dont rely on the stock oil pressure gauge either as its very innaccurate. A fitted Mechanical gauge on the turbo oil feed never lies.
Mann w85 which i believe to be the same size as original gtt is £8 on ebay. The bosch filter is very similar in price. I have never paid over £8 for a filter yet
I only had 5 minutes to check things at work this morning but my findings at present is that C405 oil filter 7700727482 has a Motrio alternative 8671002274 which is also the Motrio alternative for 7700873583 & 7700274177 filters, all within the £5-£8.50 range.
IF I get time during the week I'll try to do some more checking.
