odd one this, i've just changed the engine loom (old one had been "chopped" into)
engine did crank over with the old loom, with the new loom the TB buzzes, but turn the key to crank the engine - nothing
fuel pump isn't turning on with either loom
no spark on old loom either
auto electrician reckons its the UCH, but i found a blown 25amp fuse in the fuse box under the front bonnet, does anyone have the info on what all the fuses are?
changed the fuel pump relay and the computer locking relay, no change
we bypassed the relays etc and the starter cranks the engine fine
