A
Anonymous
Ehrmmm, cann't follow this theory, If reducing would increase power, then I would close them off completely. :shock:
ray":he4fp3vt said:opend up a can a can of worms with this thread fantastic .the heads are the next thing i want to mod after the few bits i am having done at the moment idont know if you remember ben i was the man that spoke to you over a year ago about a car which i bought which had aready had some head work done at lad this has been a worry for a long time but between you and scott i hope to have when finished a very well sorted n/a vee
Indeed mike! Less boost required, more efficient operation of chargers, lower charge temps, safer ignition control......less lag and more intentaneous torque.harry":19jpnbx5 said:@BenR Ahaaa, as you might understand, Yes I'm from the 80's environment, (even before) also stopped with it halfway through the 80's.![]()
Understand me right, I don't advocate to enlarge until you have a drainpipe, there is a relatioinship between valvesize, portsizes and airdisplacements.
No problems Harry, i know you were not advocating this, i was merely pointing out the far too common trends of people that are not as specialised as they would like to think or advertise.
And you don't want to know how much discussion I've had in the past with the shiny port people.
Aswell have i...........its not such a problem anymore, its only really the Jap/chinese/thai/malaysian/some european/some american that still do it.........but nobody uses their heads anyway lol.
With the Vee I just pick up again on the NA tuning, with what I carry from the past.
Always want to know more so I'd like to discuss this matter more with you if you want. But I don't know if this thread is the place for it.
Were we not discussing this previously via email Mr.Bouma i presume?
Since I have a spare engine to waste, I'd like to give it a go, as I understand you've got a workshop with the right tools?
I'd love to know more.
Indeed, we have probably the most advanced cylinder head/valve seat/valve refacing equipment available to the public in the UK. As far as i was made aware, Williams F1 Engineering are the only other people with the same machine in the UK. You might also be interested in some V6 related developments we are pushing. Its a small market (read VERY small) so i havent at all put much effort into the engines.
To put it in a nuttshell from what my knowledge is:
The valvethroat has the smallest area, from there on going outwards the opening angel of the port should be maximum 7 degrees, you would add material on flow areas where you exceed this, and enlarge radii on areas where you undermine it.
Yes, the throat area just before the SSR has the smallest cross sectional area. The amount of degrees divergence all depends on how well you can control the seperation of flow using alternating total flow distances and velocity changes. The proprietry casting will have a great influence of the port, and extreem downdraught ports like the old BDG/YB style cosworths have been going out of fashion. A minds eye really helps, as mathmatical solutions each apply differently to different style ports, although there is probably one ultimate mathmatically perfect port if someone could fit it into an engine bay.
The valve seat design has always been delicate, but it is a bit cheap to say that the old way 30 45 60 wasn't the right way. It was just plain simple, we didn't have the equipment of today. It was al down to manual operated milling machines, which limited the possibilities.
Valve seat geometry along with valve head design has been the fastest moving area. Its all about accurate control, and manufacture of high quality concentric and well designed seat geometry. 30-45-60 seats were better than single angles (in a stock casting) but many were able to better that by hand manipulating the blend into the single 45 degree seat. And as we do now, we are able to control that blend with a sequence of radii, angles, concanve and convex. Manual operated mills replaced grinding stones, serdi type form tool carbide cutting replaced mills, and now like we have invested in, single point CNC countour cutting has replaced serdi type machines.........i say repalced, more like obliterated.
And to you MikeT, this porting and stuff also relates to your turbo stuff if you want to get the max, so pay attention in the class:shock:
BenR":2jg0ab48 said:actually air heats up as you increase pressure/density.
