[No title]
  • Start date Start date
A
Anonymous
One , or actually 3 principal words:
Let it breath.
Inlet, exhaust, different cams. Those are the things to start with, do it in stages. Imho, THE place to start with is the exhaust manifolds.
Look closely at racing engines, then look at your engine, notice the differences in the breathing area, and adapt your engine to those, you think might work for you. It's no rocket science.
Tubing from and to each cylinder should be equal.
"Flowing" the stuff is best, it is possible to build a home build flowbench if you fancy the work of tuning yourself.
Not top notch, but it got me there when I still raced in the late 70's,
With home built stuff we achieved 145HP out of a standard 85HP 1.3liters Simca engine.
Machining some of the stuff is left best with proffessionals, like valveseats and stuff like that.
If you've passed there, then try to find somebody you trust to fumble with the computer.
Be aware though, I've mentioned it before, the limit of the gearbox is 320Nm. You won't be the first one to break the diff. casing.
that not a good enough post for you by harry?!?!
the obvious mods would be cams/decat/intake(throttle bodies)/headwork/remap.
fresh ideas on a n/a engine!
The bit most don't do is change the ecu and map the thing properly from standard before modifying - do this first and you'll end up saving money in the long run.
The rest is the same old same old - breathing - more effeciency - more horsepower as long as you can map to it.
Hey MikeT,
Intersting remark, :idea: I never thought about it to do the remapping first. :shock:
I'm old old school, so not too familiar with the bits and bytes whiggling, but if I think it over right, the mapping is actually independant of the attached inlet and outlet trackt. There is no measurements of presuredrops, so it is indeed wise to do the map first.
Geehh.... even an old school guy can learn something new.
i had mine chipped and had a lot of pinking...
i got nos now and when i want 50 bhp i just flick a switch...lol
not sure about mk2's but the mk1's can't handle a great deal of power increase imo...the clutches aint strong enough.
then contact Steve at GWR and go Motec - I believe hes working on a plug in solution so you can revert for sale and you'll have an ECU for life for all future projects - invest now and you'll save money getting things going faster for the rest of your life - try saying that for any other performance enhancer.
Mike
