[No title]
you need it to run at 80 ish degrees...
if you are having problems with cooling then sure go for it, but i doubt it...
its a large rad
Is there a lower temp thermostat for the v6? or should i just pull out the stat if i want the temp down.
just fit another lower stat I guess - no point though - fit a proper oil cooler instead of the useless one - I believe Scott is working on a kit, cooler oil beats cooler water
i will be doing the oil coller, but with weather in Hong Kong, the water is not too, with all the traffic and hot weather, water temp is always at 90-100
