Next came the engine. How much power can the car handle? What mod’s would not hurt reliability and drivability? The choice was easy: A two-stage 100 hp kit from Nitrous Express. We knew the engine could handle it. It is built to the highest standards. The engine block with all it’s webbing looks like an IRL engine and going the nitrous round would not hurt drivability, because
the engine essentially stays stock. However, in order to assure ignition when that hundred-shot of nitrous hits the combustion chambers, we had to improve the ignition system. There is nothing worse than a weak ignition and loads of nitrous. We installed Nology PowerCore coil amplifiers and Silverstone spark plugs, as well as a Nology PowerBand electronic engine management controller, which was only used to control the ignition timing. Without the PowerBand controller, detonation-caused meltdown would be assured. It looks like the laughing gas really works. Everyone who drove the car had a big smile on their face and no wonder, now, when you push that little button and activate the Nitrous Express Shark SX2 Nozzle, hold on, because now the car has 350 horsepower. Did anybody say slingshot? But pleeeeease make sure you keep your hand on the billet shift knob of the B&M short shifter while accelerating through the six-speed tranny so you don’t miss a shift, or the engine will bounce off the rev limiter while you laugh yourself silly.
The Nology ignition upgrades also improved off-nitrous performance, as did the sport exhaust from Renault, which also added to the audible pleasure even before the engine reaches it’s 7100 rpm redline. Not to mention the exhaust tips, which are so handsome, in a strictly mechanical design kind-of-way, of course.
