G
Guest
Right,
This is my next big (and quite daunting) project i've got to undertake on VEW.
Basically, i've got to move my ABS unit backwards, as close to the bulkhead and as far away from the gearbox as possible.
The reason for this is that i can't fit a top gearbox mount as the ABS unit is in the way, and my engine isn't sitting right without it fitted and it's not tight enough.
Question is, how hard do you think it'd be with the engine in situe?
I've had a quick look and it looks like the cables for the ABS unit will reach, i think i'll probably need new brake pipes made up though?
