Sorry one for the tech heads here :s
I have had my car into Renault to get the Geometry set up. Now I requested befores and afters and have posted there sheet details below. From the Geometry settings found in the Wiki part (Also Below in BLUE) I cannot work out whats what and if they have indeed screwed up!! The Spec in brackets is off the Renault Sheet - other details off the sheet are "CLIO Tubular rear axle BXXX SXXX (H5-H2=117)" under Model!!! and 1990-1999 Renault under Year!!
FRONT
CASTER LHS & RHS (Spec 0Deg 25' min to 1Deg 25' max)
LHS = 4Deg 06'
RHS = 4Deg 06'
WIKI SPEC +5Deg +-30' - Not Adjustable
CAMBER LHS -0Deg 36' RHS -0Deg 42'
WIKI SPEC -0Deg 45' +- 20' - Not Adjustable
TOE LHS & RHS (Spec -0Deg 10' Min to 0Deg 0' Max)
LHS 0Deg 06'
RHS 0Deg 12'
WIKI SPEC Parallelism +0Deg 30' +- 10' - Adjustable
SAI LHS 11Deg 31' RHS 13Deg 03'
WIKI SPEC - Pivot 13Deg +-30' - Not Adjustable
Included Angle LHS 10Deg 55' RHS 12Deg 21'
All of the above were not changed.
REAR
CAMBER (Spec -1Deg 20' Min to -0Deg 20' Max)
LHS -0Deg 36'
RHS -0Deg 30'
WIKI SPEC -1Deg 30' +- 20' - Not Adjustable
TOE (Spec 0Deg 02' Min to 0Deg 13' Max
LHS Before 0Deg 15' AFTER 0Deg 00'
RHS Before -0Deg 09' AFTER 0Deg 00'
WIKI SPEC +0Deg 45' +- 10' Adjustable
I am looking for anything that looks odd and if they have used the wrong settings - some seem okay others look way off!!.
Thanks
Si
FRONT
LHS = 4Deg 06'
RHS = 4Deg 06'
LHS 0Deg 06'
RHS 0Deg 12'
REAR
LHS -0Deg 36'
RHS -0Deg 30'
Thanks
Si
