Gentle Ben
Vee-Man
CO
2.2% (Limit 0.2%)
FAIL
HC
250ppm (Limit 200ppm)
FAIL
Lambda
0.9
PASS
It's had a new coil pack fitted which has remedied the misfire which we were told was causing the emissions failure, however it hasn't cured it.
We're being told the ECU needs resetting which 'should' cure it. Sounds like a stab in the dark more than anything.
If one of you kindly people can point me in the direction of the culprit sensor or the likely cause, it would be much appreciated.
Ben
2.2% (Limit 0.2%)
FAIL
HC
FAIL
Lambda
0.9
PASS
Ben
