MAF SENSOR CLIO V6 phase 1
Adrian":1e1grtvd said:
Check the knowledge base/manuals/engine/chapter 12
Derek
There is probably all the information you require within the knowledge base, it may help get more response to your query's if members felt you were taking the trouble to search for information yourself.
Adrian has obviously spent the time to search on your behalf and given you links to what he has found. I've looked and the information you want is clear for any member to find.
Have you had the car diagnosed using the 'Renault Clip' a lot of the components and sensors can be checked through this tool, even if no fault codes are revealed.
Also there is a very structured way to go about fault finding, I may be wrong but it seems to me you (or who you have looking into it) are picking random components in the hope that it may be 'the one'.
Sorry if this all sounds unhelpful but I'm sure we all feel your frustration with a vehicle that's not working as it should and hope you can get it sorted before too long.
