I assume when using any other tyres on a MK1 other than the recomended Michelin Pilot SP1s you need to match the load index's?
Anyone know what thse are for the Michelins/standard setup?
In the handbook it says 1.4bar for the fronts and 2.1bar fot the rears, but if you change to Toyo T1-S or T1-Rs for example, should you still run the recomended tyre pressures?
If not how do you know what pressures to run, if Renault strongly recommends the Michelins which where developed specifically for the car.
The lopad index for the tyres would also worry me....
