KW Mk1 geometry settings
  • Start date Start date
A
Anonymous
Can anyone help, I'm trying to get them done but can't find any information on them for a mk1 just a mk2 ?
Yeah , they no longer appear on any of the Garage's computers :
Primary Angles Front :
CASTER MIN 4.50 o MAX 5.5 o
CAMBER MIN -1.08 o MAX -0.22 o
TOE MIN 0.17 o MAX 0.33 o
Primary Rear Angles :
CAMBER : MAX -1.83 o MIN -1.17 o
TOE : MAX 0.29 o MIN 0.46 o
This is for a standard car , they are of no use if you have uprated your suspension or wheels as the car will sit totally differently
If you have paid so much for the KW suspension , then you should contact them for the revised geometry which should have been included in the sale , I know it is customised suspension (and therefore down to the fitter / customer's requirements) , but including the standard set-up and the revised set-up is a requirement of such a high priced item in my opinion
james":91zthzvp said:
Cheers James but they are no good as Zim says below they are for standard settings.
Thanks Zim, they were on the car when i bought it a few weeks ago and just wanted to get it checked, i have used Mossyv6 settings as a guide knowledge/kb_show.php?id=38&highlight=geometry+ so i'm hoping as its a mk2 im hoping its no biggie.
