went to get in the vee earlier and the keyfob button sunk in much further than usual and wouldnt unlock the car.
i opened it up to see that the little button bit on the circuit board has detached itself:
can i solder it back on or is it off to renault for a new one? im guessing that will be a few hundred and a few weeks wait as always [smilie=badpc.gif]
to rub salt in the wounds i went to get spare one and exactly the same thing has happend to that....so i cant even drive it to the garage.
also when you put the key in the door lock and unlock it, it appears to only pop the lock, not disarm the alarm. is that normal? i didnt want to risk opening the door and setting it off when i cant stop it, so locked it back up and walked away.
