First time this year i've started the VEE, wanted to check if my rear brakes did need rebuilding but not as bad as i thought which is good news.... Still want painting tho they look a mess lol
But upon looking under the O/S/R noticed that it seems to have a slight water leak running of the air con pipes
Nothing major at the mo but will be getting fixed as dont want it over heating or blowing a hose!!!
Does anyone know if there is a common leak from that area and if so could i fix it my self?
Not sure if am just being paranoid on this one, but took the 2 covers of from in side the car to look for a water leak. But as i put my head near the inlet chamber and coolant bottle sounds like there could be a air leak is this normal?
cheers for reading hope you can help :bow:
